disable mpls ldp loop-detection
Description
Disables LDP loop detection on the switch.
Syntax Description
Default
Disabled.
Usage Guidelines
Loop detection provides a mechanism for finding looping LSPs and for preventing Label Request messages from looping in the presence of non-merge-capable LSRs. The mechanism makes use of Path Vector and Hop Count TLVs carried by Label Request and Label Mapping messages.
When LDP loop detection is disabled, LDP does not attempt to detect routing loops.
The following command globally disables LDP loop detection on the switch:
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
